RCU Forums - View Single Post - EQ10, endpoints, and deflection.
Old 03-23-2008 | 01:57 PM
rrritchey
Default RE: EQ10, endpoints, and deflection.
Hi,
Servos come from the factor with different amounts of throw. The potentiometer that is used to determine position can have up to a 5% error, which will translate into a throw difference. You should use the endpoint adjust to match the elevator halves. Let me know if you have any other questions.
