RE: Four Star .40 Balance Question
As indicated above you need to find out where the CG is. Below is a shot of where I had my batteries when I had a 46AX in my 4* 40-Behind the servos. I also had a Dubro Isolation engine mounts which add more weight. If you can't get the CG back far enough, move your engine back or try a APC prop and heavier spinner.
