RCU Forums - View Single Post - BEC VS Receiver Battery(s)
Old 03-24-2008 | 12:45 PM
opjose's Avatar
opjose
Default RE: BEC VS Receiver Battery(s)
To clarify Rodney is talking about the built in BEC in the ESC, which is why he says it is good for planes that do NOT require a lot of current for the servos.
Hypersprint may be talking about using a seperate stand-alone BEC.
These typically CAN and DO handle higher power output requirements of higher torque servos.
I use standalone high power BECs with electric planes that have larger control surfaces and/or have a higher power ESC...
e.g. anything OVER 40 Amps.
Typically the higher the amp draw the less capacity available for the BEC's output to the servos which is why a standalone BEC is usually advised... and if you go higher, say to 80A esc's... these often do not have an on board BEC.
