RE: 5th channel activation?
Thanks Nick, Not really sure what you are saying, could you elaborate? Yes I have it plugged directly into the aux plug on the reciever. Are you talking soldering directly to the + and - pins on the reciever?
Terry
Did you just plug it into the power portion of the 5th channel? If so the power would always be on. I was wondering for some time if someone connected the positive cable to the signal pin and the negative to the negative pin if it could be controlled by the fifth channel knob. Just throwing an idea out there.
Nick
