RE: 5th channel activation?
What kind of connector do you have? I was thinking about using a connector off of a servo then connect the negative wire off the light onto the negative side of the connector. Then hook the positive wire off the light onto the signal side of the connector. The signal pin is one of the outer pins.
Nick
