RCU Forums - View Single Post - 5th channel activation?
Old 03-24-2008 | 03:06 PM
gnd2
Default RE: 5th channel activation?
Terry, you need a set of lights specifically designed to switch on and off. Some only take power from the channel connection and don't look at the signal pin to switch on and off.
ORIGINAL: evdreamer
I was wondering for some time if someone connected the positive cable to the signal pin and the negative to the negative pin if it could be controlled by the fifth channel knob. Just throwing an idea out there.
Nope, won't work.
