RE: Voltwatch, you all use 'em?
I cycle my batteries prior to going to the field. I check the battery voltage each flight and range check at the beginning of the day. When I get home I discharge them on the cycler to see what is left. The voltmeter reading is only a guide for me in the field. If I have any doubts, I will swap out the pack with a fresh one and then check the voltage again.
