You can also use two separate RX channels if you wish, and if your transmitter will handle the mix (computer radio).
On my Tiger 60, I used the Airtronics Y connector which was a tad long, but the combination of the length of the fixed wires on the servo and the 6" extensions, you will have plenty of length with any of the Y connectors you choose. As Missileman said, one may be a tad long, but that won't matter much.
Make sure you secure the connection of the servo wire to the extension so it does not come apart in flight. That can certainly ruin your whole day. Use something like this (the one shown is for Futaba, but there are ones for JR, Airtronics and so on).
http://www3.towerhobbies.com/cgi-bin...&I=LXDT85&P=ML
CGr
