RCU Forums - View Single Post - Tiger 60 servo extensions and Y harness
Old 03-24-2008 | 07:43 PM
Missileman's Avatar
Missileman
Default RE: Tiger 60 servo extensions and Y harness
ORIGINAL: Shortymet55
Can I use just the 21in Y-harness with no other extensions? I figure fewer connectors have a better chance of not coming apart.
How will you connect the Y to your servo? The connection will be inside the wing somewhere and neither lead is long enough to get to an opening. An extension can be connected then fished through but a Y harness has to go to both ends of the wing.
