RCU Forums - View Single Post - U-Can-Do 60 with OS 91FX and other suggestions
Old 03-24-2008 | 09:14 PM
waynemia
Default RE: U-Can-Do 60 with OS 91FX and other suggestions
Pictures
The Saito is ready for the first start.
There is a view of the cut-away I did for the belly pan.
The modifications for the landing gear. There is a piece of ply added and a 1/4x20 nylon screw added to the middle. The 6x32 screws have been replaced by nylon.
I started assembling the 24" servo extentions. I have one completed.
The rest of the parts should be in tomorrow.
I found some frost paint for glass and plastic. I may use this for the canopy. It is a different effect then many I have seen.
I need a piece of trim is needed to cover the bolt holes for the stabilizer. I don't want an entire roll and the LHS did not have a match [].
ID:	912760   Click image for larger version
ID:	912761   Click image for larger version
ID:	912762   Click image for larger version
ID:	912763   Click image for larger version
