ORIGINAL: ///AMG55
Yeah sorry I mean the whole wheel and tire. After I take off the lug nut, I cant seem to get the wheel to budge at all. I cant get this stupid wheel off without feeling like im going to break something else on this thing, by pulling on it so hard. ??
Yeah I know what you mean and I asked the very same question when I got mine. After the wheel nut was off, it felt like the wheel was still glued to the hub or there was some other kind of grub screw that I hadn't loosened off. Turns out that they are just a very tight fit on the hub. I think I used screwdriver placed in the centre of the hub with the fat end resting on my gut, and then grab the rim as close as possible to the hub and PULL!
After it was off, I give the rim hole a light sand so it went back on easier and havent had a problem since.
Your rims wouldn't happen to be yellow?
