RCU Forums - View Single Post - How long does a battery receiver charge last?
Old 03-25-2008 | 12:55 PM
Acs_guitars's Avatar
Acs_guitars
Default RE: How long does a battery receiver charge last?
ORIGINAL: Nathan King
That's pretty much what I do.
With that setup you will be generating 2.1 to 2.5 watts or even slightly more, so I would recommend upping the wattage rating on the resistor. The setup will draw anywhere between 436mA to 533mA depending on the particular resistor (5% tolerance - gold band) in case anybody is wondering.
If you use conservative quitting voltages you will be fine.
What wattage do you recommend? Mine maybe be higher, but I would have to look, it has been a while since I put it together.
