RE: SCARY PROBLEM WITH NEW AR9100
Just installed a new AR9100 system in my TJ F-16 this morning (after checking the soft switch, I cut an additional 1/8" off the middle wire). I ran it through the binding process, and all I can say is WOW, what an easy process.
I need to locate the 3 receivers somewhere in the fuse now. I have one (port A) located on the component tray, wires heading outboard and laying flat, antenea pointing nose/ tail. Where do you guys recommend the others be located?
Thanks!
Mark
