RE: bandit arf by-pass????
You could install the underslung wing tanks if you wish.
I am not sure if the internal structure of the ARF wings have the hardwood blocks installed, but there is more than one way to add the mounts.
The tanks are available from BVM for $155.00 per pair, and include the pylon kits.The pylons are made from plywood and balsa, and are very easy to fabricate.
The part number is 6705.
All of the necessary instructions are on the Super Bandit drawings.
You can contact Dustin Buescher at BVM to find out where the internal structure is located in order to install the tank mounting blocks. 407-327-6333
Dustin is the Bandit ARF daddy. He heads up the airframe design group.
My pylons contain the pnuematically operated BVM EZ Drops so I can drop the tanks or drop bombs in flight.
I have an extra air tank with a micro servo operated air switch operating the EZ Drops.
Harley Condra
BVM REP
JetCAt REP
