RE: bandit arf by-pass????
Lateral Balance:
Balance the wings individually first. Add weight to the light wing as follows..example..if the right wing is 1oz heavier than the left wing, add 1/2 oz of lead in the aileron servo pocket of the left (lighter) wing. Glue the lead in securely.
Install the wings, and balance the aircraft right side up, gear down, zero fuel and full UAT.
It should be the same upside down....CG is CG.
Harley Condra
BVM REP
JetCat REP
