RCU Forums - View Single Post - Using the same TX on differnt planes
Old 03-26-2008 | 07:53 AM
de bong
Default RE: Using the same TX on differnt planes
the tx/rx from art-tech is 35mhz and the ZX10 is 35 MHz 5+ channel FM proportional....I presume if I bought a tx/rx from the US I would have the change the crystals to 35mhz...will this work?
Also the servo's on both planes are the standard 3 wire config...
thanks again for all you help....
I think I will check UK and ireland first for the rx/tx mentioned above
