RE: 50cc Sukhette Build Thread, now in progress!!
Jim, I am currently trying to wrap up my Suhkoi. I have a Wolverine switch installed also. This was purchased well before the new Kodiak's came available. I was hoping to use a A123 battery for both, the rec and ign. Do you know if this would be possible with the one Wolverine switch? Using the 2 outputs from the battery to the switch and then 1 output from the switch to the receiver and the other to the ignition. Or my option "B" is to install a Badger switch for ignition and just use the Wolverine for the receiver. Opinions?
