RE: new design: Strega 45
Now I will make the ailerons working, the hinge from kevlar is allready glued in the wing.
I will cut the foam and cut the sides. The bottem skin has been cut CNC. The top of the wingskin will be carefully cut just to the kevlar. After that the hinge is working. You will not need to do this it has been done here before shipping.
When the aileron is working it is time to glue the wings together with ZAP 5 minutes on a wingjig made of MDF.
