RE: 50cc Sukhette Build Thread, now in progress!!
Darkwarder,
I'm not sure if the wolverine switch will work for you the way you want to use it. Its really meant to be used with two seprate batteries to power your receiver and servos, as it has a monitoring system in it that will draw from the stronger of the two batteries to keep the voltage even. I'm thinking that you might have a problem with that. That being said, I am still a big believer in dual or redundant battery pack. Three weeks ago my good friend lost his scratch built skybolt because his one and only battery failed in flight. For the little weight gain and extra expense its not worth it to me.
Jim
