GP Lancair, I've flown it!!!!!!!!!!!!!!!
looks good,
I'm just finishing mine with a OS 91fx.
I too noticed the flaps sticking to fuse, if you look good you'll see it is probably due to not gapping enough clearence between fuse and flaps.
In other words don't CA the flap hinges in until you put the wing on the fuse first.
I had to cut a little corner off my flaps because I did like the manuel stated. I CAed mine in first before checking for proper clearence.
