RE: Nexstar Engine Mount
I just called a LHS and he said that the engine mount should be pretty close to mounted in the center of the firewall; mine is over 1/2" offset. I thought this was to make up for the spinning of the engine, but there is also a bevel to the firewall, which maybe if the engine is mounted in the center the firewall would be sufficient to offset the spinning action?
