RCU Forums - View Single Post - Nexstar Engine Mount
Old 03-26-2008 | 06:22 PM
nobodytwo's Avatar
nobodytwo
Default RE: Nexstar Engine Mount
ORIGINAL: FatOrangeKat
ORIGINAL: fredsedno
Had the same problem,shaved cheek,then discovered the engine mount was offset more than 3/8" to the left[driver side].
Nothing in the front of the plane seems to be lining up correctly, including the nosegear, etc. I wonder if my engine mount or something is misaligned.
I understand there is supposed to be some correction for the fact that the spinning engine wants to pull the plane to one side, but my engine mount is 5/8" clear on the passenger side and 1/8" clear on the drivers side (to the beveled corner of the firewall)...does that seem right?
I was able to drop the engine in fine, with the removal of one of the screws holding in the remote needle, but I would need a decent sized muffler extension to get the muffler to clear the side of the plane.
I'd have to remove a lot of wood if I was going to start cutting to get it to fit. Also, I could try to move the whole thing forward 1/4", which would get the engine to fit, but probably cause more misaligning of steering rod, throttle arm, etc.
You sure you don't have the engine mount upside down?
