RE: blet cp problem?
The part you are talking about is the spindle shaft. Are you in idle up? If it is squasing against the floor you have negative pitch. I would recommend to check the pitch of the blades. You could have ground wash that low to the ground. If you have the stock transmitter check that the knobs are in the right spot. Druss had a good explanation about what each one did.
