RE: wont be runnin for a while
the only thing is, when you are takeing it apart take out the glow plug first then remove the head then the sleeve then the back plate then the conecting rod then the clutch and fly wheel then remove the crank. check it all for scratches. and if the conecting rod is gone might as while buy a new engine... what engine do you have?
