RCU Forums - View Single Post - A few things
Thread: A few things
Old 03-27-2008 | 06:20 AM
vnmsgt's Avatar
vnmsgt
Default RE: A few things
ORIGINAL: Swamp3r
I ran my monsoon today and noticed something wierd, one of my back tires is really loose but the lug nut is very tight. Can I put a washer in there to take up the slop? the other tires have a smidge of slop. Should I just add washers to all 4 tires.Yes the tires are on properly.
The other thing is I see long posts about other redcats but none of the monsoon is it causes nobody likes it.
check the bearing that is inside the rear upright that you axle goes through and make sure it is good and the rear upright is bolted tight to the arms. Also did you wheel nut fall off or come loose before that while running because the inside of your wheel that goes onto the axle hub hex part may be stripped our gouged up and letting it be loose.
