TIP for anyone with the ally fuse. If it bends and slightly crumples get a stick less than 10mm (metal/wood etc) thats strong. Stick it into the fuse and push till it meets the bend or obstruction and then gently bend the fuse till the stick goes thru - remove the stick and the fuse should be OK and straighter. If you just bend it without inserting anything it will crumple and break or worse............I know from experience!![
][&o]
