RE: differences between cvr and cv rx
Like clermont said you need the 11J rotary carb. The slide will not work and if you get the one with the short shaft you can get the shaft extender that will change it to the sg shaft type. It screws right to the short shaft and makes it Sg. So the one you are bidding on will work.
