This is a tough question to put into writting so bare with me.
I am not understanding the way the 9303 gov function works with the futaba GV-1. I have the Govenor function active in the 9303 and my GV-1 plugged into channel 5. I have a 7 channel receiver so there is no gov on/off toggle switch. I am trying to activate the govenor in normal mode at a set throttle position. When I access the RPM setting screen on the governor and switch between flight modes the govenor rpm setting screen stays on s1 and does not let me set rpms in any mode.
when I set 1, 2 or all 3 flight modes to 0% I get the same results: off-s1 and "rpm"-s2. So I can only set the RPM for s2 and not for s1 or normal. How do I get it to let me set the rpm's of each flight mode?
Also what does the 100% mean in the 9303 governor setup screen? My guess is that it varies the top end rpm slightly acording to how you skew the 100% in relation to each flight mode....ie 0%-125%
I did my best to set up the governor/radio and did one test flight and then looked at my max RPM...it was 21,450rpm [:@] I don't want to experiment anymore so I am turning to you guys
ty
D
ps. I had everything working fine with my 7202 but it doesn't have the govenor function that my new 9303 has.
