RCU Forums - View Single Post - lube question?
Old 03-27-2008 | 08:50 PM
horace315's Avatar
horace315
My Feedback: (15)
Default RE: lube question?
i use what they call assembly lube.which is a product called luberplate.it looks like white grease but is very soft like butter.almost any motor oil will work also.whatever you use you just want to cut down on friction which causes heat and metal to metal contact.after you run your engine all of that lube will be washed away with whatever oil is in your fuel.
