RE: FAAST and Hitec servos
There are reports that some non-Futaba servos don't work with the R6014FS receiver because the new technology in the receiver has a lower-voltage signal level than some servos are able to interpret. This lower voltage resulted from the type of circuitry required to attain the processing speeds. Newer chips use lower voltages. Some older servos may not operate well with the newer receivers.
