RE: Installing control horns
Minn Flyer.
I have some of these laying around! Being new I was apprehensive to use them.
They look simple enough, however, don't you have the same problem with aligning the single bolt ie crooked, etc or is this the same principle? A little larger hole for proper alignment/fill in the hole with balsa/ca, clamp it down and you're done. right?
