2.5 Engine= JUNK!!!
To eliminate vapor-lock, reroute the fuel (not the pressure) line away from any heat source. If you are going to lengthen the fuel line (to reduce starvation when the car is flipped) make sure it is away from the cylinder and/or the exhaust system.
