Bobcat elevator servos
I had the linkage attached to the outermost hole on the servo arm. Probably could have tried to move it closer to the center, but really wanted to go to a metal gear servo.
I need about a 1/4" shorter servo to align with the existing horn. Both servos will probably stick out the bottom of the stab, but I figured I could make some kind of cover for it to smooth the airflow.
Mike
