Originally posted by TonyF
Where are the DR settings and the Trace Rate? In the 10X, the Trace Rate default is 100%, but it can go to 150%. Increasing that will give you a lot more electronic throw.
Also, just how much elevator are you using? If you're trying to throw it more then needed, you will reduce the power to the surface.
I fly futaba and never fly on low rate elevator..... BTW what is trace rate???
Todd
