RCU Forums - View Single Post - Bobcat elevator servos
Old 04-29-2003 | 03:53 PM
Jetjock51
Default Bobcat elevator servos
David,
What is your trace rate set at? Mine was set at 100%. If yours is 100%, then ours were set up identically. I set mine up that way because yours was working well. I did not want to use the long servo arms because I did not want the reduced leverage inherent with that set up. The elevator horn was installed per the plans with the clevis hole at the hinge line and the recommended distance from the surface of the elevator. I was very careful about the setup of the elevator servos.
Dennis
