RCU Forums - View Single Post - Bobcat elevator servos
Old 05-07-2003 | 09:16 PM
  #108
Doug Cronkhite
My Feedback: (34)
Default Bobcat elevator servos
Originally posted by S_Ellzey
I would stay away from the lithium batteries for this application. they can be very touchy. I they are of the smart pack design they can turn them self off to prevent damage, charge them wrong and they may catch on fire, go below 3.3 volts per cell and they may be damaged, and you can not fast charge them, one hour is about as good as it gets. Steven
Not quite Steve.. Non of the current brands use the circuit protection in the pack itself. They will both happily allow you to discharge them to the destruction point. The voltage protection is available.. but not used by default (I'd never use it).
Fast charging isn't an issue because of the sheer number of flights possible with a given pack (unless you're Jason Somes.. and fly 15 flights a day). The current ECU packs being tested will give you 10 flights without charging. Kent Nogy has been using them for evaluation and has shown that performance including using the ECU pack for the cooldown cycle in the P-120.
The other issues are real but are of little consequence if you pay attention to the details like we all should be with jet models.
Doug Cronkhite
Team JR, Duralite Plus
