RCU Forums - View Single Post - FLy Eagle Jet Models
Old 03-29-2008 | 02:29 PM
  #875
bigplumbs
Banned
Default RE: FLy Eagle Jet Models
ORIGINAL: lookilook
hi ziv,
they are currently attached to the rail with a very strong double tape that i use on real aircraft ,cause is not ready for flight yet i cannot say for sure that is a good idea,tomorrow i will make an effort to copy a system that i saw in a model show f16 where you make 2 L shape "teeth" on the side of the missile and 2 slots on the rail and these 2 teeth are slotted inside in the direction that the wind will be pushing them against the slots so as to not drop or move.....may be not so clear but when i finish it i will post some pictures
to see...
regards NICOS
Use 4 mm gold connectors that you use on ESC's have the male on the misile and the female in the end of the wing.... They are very tight and wont come off in flight
Dennis
