RCU Forums - View Single Post - CA vs. Epoxy
Thread: CA vs. Epoxy
Old 04-29-2003 | 04:50 PM
hookedonrc's Avatar
hookedonrc
Default CA vs. Epoxy
That raises a question for me then. If CA is the best to use in construction because of its weight, how would I glue on my top sheeting? For example, I am building my first kit, a Someting Extra. I have come to a point several times when I needed to put the sheeting on the leading and trailing edges, and on the decking closest to the Cockpit. Because the wing is still pinned to the plan on my building board, I was unable to get under the wing to apply CA all along the contact area. I used 5 min epoxy because I could put it on the ribs, and then wrap the sheeting along the curved part of the front. With CA curing so fast, is there a tip that I should know about in order to use CA on this part?
