Glue Options
Titebond (not the II variety) is light and easy to use. If you make a mistake heat with your covering iron to reactivate the glue. I don't use many clamps and simply use doubled masking tape to hold things in place. This glue attains about 50% of overall strenght in 15 or so minutes. Takes about 24 hours or more to fully cure. This glue is considerably stronger than Elmer's woodworkers variety. Don't use this for sheeting foam wings! Use polyuretahne glue or epoxy for sheeting.
EXCAP232
