Originally posted by MinnFlyer
Admiral, the simplest way to see if your engine is ringed, is to remove the muffler, and turn the prop until you see the top of the piston. If you see the ring, it's ringed!
Oh come on, every time I have finished running that engine I tighten all the bolts on the head and muffler. After flying this weekend I went to tighten those bolts again and they finally didn't need to be tightened, although I will still check them after flying. I just don't want to take the muffler off and go through all of that again
Oh well, I'll check that when I get home tonight. It will give me a reason to head to the basement after dinner
Using the break in method I described above, I guess that I should be hoping I have an ABC engine???? If it is ringed, am I in trouble?
