ML,
I've found my retracts need a fair bit of pressure, so can't slow them down much with the Robart valve. I put 120 psi in and get 8-10 cycles using the large air tank, but up and down with a "clunk". Will try to slow the speed as they loosen up a bit.
Setting up radio today, used the servo speed on the JR PCM 9xII to set 2 sec on flaps and 3 sec on bomb bay doors, and finally worked out how to get the elevator mix to move slow with the flaps - looks cool!
Also set some "toe-out" on the rudders to help in an engine-out, not that I plan to have one you understand.
Back to details.......
