RCU Forums - View Single Post - Evolution 26 problems
Old 03-30-2008 | 07:05 AM
Ravivos's Avatar
Ravivos
Default RE: Evolution 26 problems
Jon,
it seems that you have the older version of the ignition.
does it sais "4.8V" in blue on it?
if so, these ignitions are very sensitive and it might be malfunction.
i had one of these ignition that burnt.
eventually i changed the entire engine to GT2 with the new ignition module.
on one of my gas engines (DZY 26cc) i had a similar problem, the engine didnt hold a full throttle for more than half a second and was sound exactly as you described.
i found out that one of the DC capacitors (internal component) of the ignition module broke off - probably due to vibration.
