RCU Forums - View Single Post - Push Pull vs Pull Pull
Old 04-29-2003 | 10:44 AM
Stick Jammer
Default Push Pull vs Pull Pull
The decision to go with a pull-pull setup usually rests on how the plane will balance out. If it needs tail weight, the servos are installed on the rear (push-pull). If the plane is already tail heavy, then a pull-pull is used which locates the servo/servos much further forward.
