I replied to you already.
You have to take the diffs out of the rear and front bulks first. Then open the front and rear diffs up. The center diff just remove, then take the spur gear off and fill.
Here is a picture of the rear diff case. Courtesy of AMAIN.
Before filling make sure you clean and get as much of the grease out as you can.
