RCU Forums - View Single Post - What To Do With Old Gas?
Old 03-31-2008 | 07:20 AM
DAKOTANOVASS
My Feedback: (17)
Default RE: What To Do With Old Gas?
You can put in your vehicle, then go fill up you tank, actually the oil in the gas is good for the valves, it will give them some extra lube. Todays gasoline is dry (contains no lead) which helped lube the valves. So that little bit of oil in a full gas tank will not hurt at all.
Terrell
