RCU Forums - View Single Post - LiPo battery size => flight duration?
Old 03-31-2008 | 08:31 AM
CGRetired's Avatar
CGRetired
Default RE: LiPo battery size => flight duration?
First of all, you must be sure the ESC will handle this higher voltage. Second, a larger battery means heavier flight loads. You could run into a situation that the plane is to heavy to fly or you consume more power based on the heavier weight.
