ORIGINAL: JRFisher
I quit using a single servo for ailerons years ago.
Put separate servos in each wing and you'll be glad you did. Depending on what radio you have dual servos can be used for different things as you progress.
Hi,
I'm putting servos in a wing now, what is the best servo for a fatuba fm system in the wings? Its not a thin wing core , and its a trainer. Its about 1.3 inchs thick, I could use a reg servo if the weight is not a problem.
thanks
