RCU Forums - View Single Post - OS Speed 21VZ-B V-Spec ?
Old 04-01-2008 | 06:31 AM
  #38
HighClassBasher
Default RE: OS Speed 21VZ-B V-Spec ?
ORIGINAL: Farfa
so you are telling me to go with O.S. T-2060 SC WN TUNED PIPE.21 VZB V-SPEC
Yes. This tuned exhaust is specifically designed for the V-Spec SPEED. It brings the V-Spec Speed engine to its fullest potential in all aspects, even significantly longer run times, ive seen run times go up as much as several minutes per tank by switching to the 2060[X(]...[8D]
