DP Ultimate Questions
lnorris,
I got a chance to slide the fin in and mine is flush at the front but sticks out in the back. I will just cover the exposed balsa.
Both my wings are warped. Bottom is 1-1/4 degree and the top is just shy of 3/4 degree. I will try to twist this out using a heat gun.
I thought the plane was blue but the actual color is ultracoat pearl purple. Exact match of my H9 80" Cap. I think I'll go ahead with the HS225BB on 6.0 volts for the ailerons. I have a spare HS5945 I think I'll put it on the rudder. The 5945 is one fast powerful servo.
Need to fabricate something to keep both elev and rudder servos centered in the fuse.
I should get started soon and hope to be finished in a couple of weeks.
Dave
