RCU Forums - View Single Post - Extreme Flight Extra 58"
Old 04-01-2008 | 08:52 AM
  #52
sdstick06
Default RE: Extreme Flight Extra 58"
jwk72....
Bolt the supplied mounts up to the firewall and measure the inside of the beams. The 82 needs 35mm between the beams to mount. See what ya got then you can either get your Dremel and slot the mount holes.... or tap the T nuts out of the firewall... slot the T nut holes and re-install the T nuts (blind nuts)
Hope this helps..
SDS
